I have a 1940 9N. I took off 12v generator with external regulator. Replaced with Delco 10SI. Added Radio Shack Diode 276-1661 (6A 50PIV) in wire from accessory post to P1 post with band toward alternator. Everything work fine at first. Was able to shut-off and restart. Ammeter was reading 20 at first then dropped to 10. After about 5 to 10 min, the tractor stopped. Found diode had burned out. Tried another and that burned out right away. Is it more important to have the amp reading of the diode higher or is the Peak Inverse Voltage more important? Or is something else causing my failure?
Wayne
Wayne
