sboutmilcav
New User
Ok this one has me stumped.
I'm not new to "N's" Learned to drive working fields on my Dad's '40 9N. Unfortunately years back Dad had a stroke and had to sell it. Been putting together a '42 2N to be like Dad's.
Finally got a Ferguson side mount sickle bar mower (Dad's originally belonged to the phone company). Got it mounted, replaced the lifting cable and when I went to engage the PTO to adjust the cable, it wouldn't go into gear.
No signs of sudden failure, lever just wouldn't move.
Got the tractor in the shop. Pulled the side covers, upper lift assembly, and stared to pull the PTO shaft. (figured that while investigating it's a good time to inspect the shootin' match and repair what I can. Less to do when I get to restoring). Funny thing is that the flange / bearing assembly came only about 1/2" to 3/4" out and stopped cold. Have to tap with mallet to put back in. Even more strange is that while it's partly out I can now throw the PTO lever in gear and when I crank the engine, the pump, PTO, et al work "correctly". Put it back in and I can't engage the PTO.
When it's partly out I can pull with all I've got. Put a drift pin through the PTO's hole at the end (for keeper pins on implements) and tap with mallet. Still won't move. Don't see anything but residual contaminated oil in caseing and can't figure out why the shaft won't move. Appears to be hung up in the pump but might not be.
Since I need to pull the shaft to drop the pump and I need to drop the pump to see what's holding things up, I'm at a loss.
Anyone out there with any suggestions on how to pull the shaft?
Thanks.
Thanks.
