After finally cleaning all the grime off an NAA I purchased last year I can now see some minor oil leaks. The first is between the mating surfaces from the engine to bell housing. I'm assuming this is a rear main seal. The front seal appears to have a small drip also.
Just behind the clutch/flywheel there is a square pattern of very heavy bolts with lock washers. Looks like something heavy was intended to be affixed here. Anyway there is also a drip coming from a couple of them. Just what are the purpose of these bolts? I had assumed that they didn't even go into the above compartment but they must if oil is coming out. could this be coming from the rear main leak and exiting back here?
These are very minor leaks, maybe one drop every two days if just sitting there not in use.
Right now money is a bit tight so I don't want to deal with this until next year if they can wait.
