I did a brake job on my 2N perhaps 15 years ago including Sure Seals. Last weekend I got tired of having crummy brakes so I tore into it. Left brake is OK and is dry. Right side had NO brake and was oil soaked, so I'm replacing that side. Trans oil level is at 6 o'clock bolt hole. When I removed the Sure Seal there was several ounces of oil inside. After staring at it for a while I'm convinced it's about impossible to keep the brakes dry. Problem is the trumpet flares out so any oil that makes it out to the end of the trumpet can't drain back into the sump. If you're lucky the oil will leak out the back side of the backing plate, but I'm never lucky so it leaks down the inside into the brakes. So, I'm thinking about grinding a grove in the end of the trumpet to help any oil that makes it out there drain down the outside. Wadaya think?
