I have a 52' 8N 12v. and it has worked fine for sometime now and just a few weeks ago i replaced the points, condencer, and roter. After that it ran fine for about 30min or so and then started running bad under a load, I checked the points and they were slightly off I also checked all the fuel screens and they are clean (as of about a month ago new plugs, and wires) I got it back running right again and it did it again about 30-45 min later. I checked the points again and they were slightly off so i fixed them and replaced the distributer cap because it was bad. Now today I went to plow some snow (yes snow in oklahoma in march very odd) and it fired right up and ran about 5min and then just died, It started right back up and would only run with a little choke, I got it to warm up and run without the choke again and went to back out to plow and it started running bad again and would try to die. I could keep it going with a little choke but not well enough to even move it, it just would idle. What is up with this? Thanks for all the help.
