I have fixed the broken valve and valve springs and have put a new metal head gasket on the tractor and torqued the head according to the F0-4 Manual. I breifly started the tractor to make sure everything sounded okay. I know that you should warm the tractor up for a good 30 minutes and then retorque the head. Before I do that I have some other questions. I have noticed that after reading different posts on this forum, it seems some people put gasket sealer on the head gasket and others don't. Does it depend on the type of gasket you use and should I be using gasket sealer on mine? I also noticed that it was recommended to put thread sealer on the head bolts. When I put mine on I didn't. What type of sealer do you usually use? Can I take them out one at a time and put the sealer on them without draining all the coolant out (given I don't have to take the head back off to put sealer on the head gasket)? Once all the other sealant questions are answered, when do you retorque the head. Right after the 30 minute warm up? Before it is totally cool? After it is totally cool? Sorry for the long post and thanks again for all the help.
-Hiney
-Hiney
