G6 at Snook, TX
I am going to try the John Smith modification on the three ring piston for the hydraulic cylinder. If I use two steel rings and the third groove is for the backup washer and o-ring, how should I set the steel rings when I insert the piston into the cylinder? For example, should they line up, or should the gaps set to opposite sides?
Finally, does anyone have a measurement on how much I will have to machine the third ring groove to imitate the NAA piston?
Thanks.
Thanks.
