Hey gang,
I was wondering if anyone has a web page or a link to a specific thread on this forum that gives good directions for converting to 12 volts, positive ground. I'm working on a '40 9N. I've converted a Farmall H to 12V before, but I did it using darn good directions, and the 6 volt system was completely removed before I got it, and I just want to make sure that I'm doing the 9N correctly. I searched the archives here, but never really found what I was looking for.
Second, I seem to be having governor/throttle problems. When I get the tractor started (which seems to be hit and miss), the throttle/governor seems to be frozen. I can't turn the lever very much at all, and the tractor doesn't respond to any movement in the lever. I can just creep around in first and second gears, but if I try to put it in third, the engine just bogs down and dies, since I don't think the governor is moving. Any suggestions?
Thanks!
-Parke1
Thanks!
-Parke1
