Order Ford 8N Parts Online
how much can a 50 8n 3 point hitch lift
hawk36
08-15-2007 20:13:06
just curious as to what lbs my 50 8n 3 pt could lift max.
Ray Iowa
08-16-2007 09:48:28
 Re: how much can a 50 8n 3 point hitch lift in reply to hawk36, 08-15-2007 20:13:06
I think a better question would be: How much should you lift without risking busting some part of the tractor or putting yourself in a safety risk situation. Adding weight up front is good for safety but stresses the heck out of the three point attachments. Get a larger tractor if you need to lift heavier loads. I sold my JD 1949 B because it would blow the gasket on the cylinder when I hit a bump with my 5 foot B'hog raised up. My 8N can lift the mower fine because of my loader on the front. I drive very slowly with it though due to my hours of gasket-changing "experience" on my JD-B.
Brian Bell
08-16-2007 05:01:43
My 8N's front end gets awfully light at about the 500-600lb range. When I have my extra weight attached to the front, it rides and turns much better with my Dearborn 11-135 disk or JD 513 brush hog on the back.
Jim.UT
08-15-2007 22:29:16
About a month ago I bought a pallet load of 80 lb bags of concrete mix. I transferred the load from my truck to the garage using pallet forks on the back of my 850. I was able to move half the load at a time....21 bags x 80 lbs = 1680 lbs. Plus the weight of the pallet and the weight of the forks, the total was probably close to 1750 lbs.
third party image
But in order to do it I had to put a bunch of weight on the front. I used two lengths of railroad track, one about 36" long and the other about 50" long, plus a solid steel trackhoe pin, 3" diameter and 30" long. I weighed each piece and found I had a total of 265 lbs on the front bumper and that only just barely kept the front wheels on the ground.
third party image
Luckily I only had to pull forward about 10 feet to clear the rear of the pickup truck, then back about 15 feet into the garage where I set the load down. I would not dare try to travel any further with that much of a load. It sure beat moving those bags by hand!
The 850 is a bigger tractor than your 8N so don't try anything that heavy.
Dell (WA)
08-15-2007 22:00:23
Hawk..... ...due to the short wheelbase of yer tractor, yer 3-point lift capacity is about 500#. Iff'n you chained yer front axle to the ground, yer 11-hole drawbar can lift about 1200# before the internal hydraulic safety valve pops..... ..Dell
old
08-15-2007 21:33:45
If all is right it will lift more then is safe to do. I.E. it should lift enough to be able to flip the tractor over if your not careful. On a 9N I have I hooked my 6 foot disk to it which had about 500lbs of weights on it and the front of the 9N came off the ground as soon as I tried to lift the disk. If it had been a boom pole it could well have flipped the tractor over
Jimmyjack
08-15-2007 20:30:08
depends on the condition of your system, but somewhere in the range of 800 pounds?
