Order Ford 8N Parts Online
8n sherman transmission.
Ron Rogers
05-22-2006 10:30:46
First I would like to thank Kelly Jewel for teaching me how to break my clutch free on my 9n. Thanks Kelly, worked like a charm.
Okay, now for the next techie question. I have the opportunity to purchase a 8n with a sherman transmission. However, after reading Mr. Smiths 8n pages on Sherman transmissions,I am confused. First I thought there was only one Sherman tranny. Okay, now I know there are at least a couple types. I now (thing)I know that the one with a long shifter is a hi/lo configuration. The one with a short shifter is a whole other set of running gears ( I think) Then I learn that there's a "Cable Type" Of shifter also. Okay, so the question is this. How do I know what I am buying if it has the cable shifter? Does that denote a type of Sherman? Thanks guys/girls.
RFR
Jerry Marks
05-22-2006 22:57:30
 Re: 8n sherman transmission. in reply to Ron Rogers, 05-22-2006 10:30:46
Ron,
Look in the archives on this site under Sherman Transmissions and you will find a wealth of information with pictures to better assist your research on the Shermans. Everything you ever wanted to know about them is there. Happy hunting!
Jerry
jimNCal
05-22-2006 17:54:31
Close sounder. The 'Steps' are EITHER overdrive/standard (1:1.5) OR underdrive/standard (1.55:1)in BOTH lever or cable. The cast lever that bolts on from the outside can belong to either a 'Combo'(hi/lo/standard) OR the 'Creeper(extreme underdrive @ 9.25:1). Actually, the true 'Step-downs' came in 2 ratios but too much information..... ....
souNdguy
05-22-2006 10:43:34
The cable shifter units were generally overdrives, and the shifter mounted ont he dash, with a pull knob. Mnay times the cable is bad, however a few people are now making repop shifter cables, and at least one person here has converted a cable type to a lever type with lots of love and sweat.
If your shifter is "s" shaped ( dogleg) and thick metal.. it is either a combo, or an underdrive. if the shifter is a round rod with a single bend, and a knob on it.. it is an overdrive.
Smerman made lots of trannies, as did many other companies.. some were pre trannies.. some were post trannies.. Hupp, everet howard.. etc..
Shuttle shifs.. reversers, live pto setups.. etc..
Soundguy
