TractorLinks.com
Order Ford 9N Parts Online
Wiring Diagram for a 9n Ford
Ray White
06-17-2005 15:33:27
Does anybody know where I can get a wiring diagram for a 1942 9n Ford with a cutout and a resister? I"ve got an IT Manual but its not very good! It covers 9n, 2n and 8n and is not real specific about any one. I"ve got a new amp. meter on it and a guy told me I can"t use it on a negative ground and that it must be like the original which is an inductive type rather than a 2 terminal setup??? Can anyone help?
Thanks
Ray
( Pic ) Ken N Tx
06-18-2005 06:26:02
 Re: Wiring Diagram for a 9n Ford in reply to Ray White, 06-17-2005 15:33:27
Check out Tyler Neff's (remember him?)
Dell (WA)
06-17-2005 16:13:57
Ray.........always thought the I&T FO-4 9N/2N wiring "pictorial" was a pretty good. You should see some of the missle and aircraft wiring schematics I've had to read. Even my Dodge Cummins Diesel is a SOB and it don't even have sparkies; I'm still looking for my radio dashboard lights wiring. The early frontmount 8N pictorial has the correct wire color codes. Just ignore the 2-terminal roundcan solenoid operated 8N starter and 3-wire genny with 4-wire squarecan voltage regulator. Sparkies and ignition are the same with 2N/9N's.........Dell
D. R. White MN
06-17-2005 16:02:52
Ray, What Rob said about the amp. meter is right. Below is another wiring diagram. Hope this helps. Dave.
Rob
06-17-2005 15:44:20
Guy gave you a bum steer with that neg ground stuff. You can wire up the post-type meter. Just cut the wire and terminate them on the posts. If it reads backwards then swap the wires on the posts.
