TractorLinks.com
Show Parts for Model:
Should I do NAA Valve Adjustment?? (PIC)
bigdawg
05-15-2005 17:21:01
I am getting ready to remove my loader and do a 12 volt conversion on my NAA. (Please don"t comment on this. To each his own. I don"t want to have that discussion.)
I was wondering of I should also do a valve adjustment? When I idle down as low as possible, I can hear some ticking, which I think is the valves.
THe engine has good compression at around 120 in each cylinder. The tractor has good power and runs fine.
Should I be concerned about the valves or just keep runnin er?
Doug
Wisconsin
LarryNAA
05-16-2005 03:41:44
 Re: Should I do NAA Valve Adjustment?? (PIC) in reply to bigdawg, 05-15-2005 17:21:01
Adjusting valves on an NAA is pretty easy to do. The Shop Manual claims you can do it without removing the gas tank, but I find it"s easier with the tank off. If I were you, I
would adjust the valves, just so you know they are OK. Plus you can eye-ball the valve springs, retainers and such, while you are at it. Not to comment on your 12V conversion, but when I converted my NAA, I put in electronic igntion. I have not even thought about points in 5 years. Handles cold (-20F) no problem. Since I put in electronic ignition, the only reason my NAA ever dies on me, or won"t start, is when all the gas in the tank is mysteriously replaced by....air.
Steve IA
05-16-2005 03:21:45
If you decide to do it, here's a link to Zane's instructions on how to do it.
Dell (WA)
05-15-2005 18:32:31
Doug.........I don't have enny problem with your converting yer NAA Jubie to 12v.
As for clicking OHV rocker clearance, MORE CLEARANCE is better'n NONE. Insufficent valve clearance will lead to burned exhaust valves.
I just checked yer OHV specs: 0.015 Hot. Usually they allow +/- 0.001 variance (tolerance) from spec. Me? I always adjust for MAX allowable clearance because as time goes by, the clearance closes up. By setting clearances to 0.016, I can go a very LOOOooong time before I haffta reset the valve clearances. And iff'n they're ALL set the same you won't hear one clackin'way.
But BEFORE I started grabbin' feeler gauges, I'd rig up some sort of "stethascope" (lenght of rubber hose) and IDENTIFY where yer suspect "clacker" is located. 'course, iff'n ya gotts time to burn and gotta an ITCH to scratch, and you just gotta tweak yer valve clearances, go right ahead.........respectfully, Dell, a 12v advocate for the right reason
Mike OH
05-15-2005 18:26:16
Really nice looking rig. My Jub has noisy valves also, from idle to wide open. I"ve been planning for years to adjust them, but haven"t gotten around to it yet. And maybe this year I"ll put the loader back on..... hope that white stuff is all gone til next year. LOL
R.M. In AL
05-15-2005 17:43:57
I have been wondering the same thing for years so Im gonna run er.I must say that is one of the best looking tractor loader combos I have ever looked at.They seem well balenced togather and not loader overloaded as some are.Nice Rig will trade ya...R.M. In AL
bigdawg
05-15-2005 17:48:37
 Re: Should I do NAA Valve Adjustment?? (PIC) in reply to R.M. In AL, 05-15-2005 17:43:57
THanks,
I rebuild all the hydraulics with new spool and loader cylinders. It really works great but I could use power steering. I don't use it much but it is really great when you need it.
Thanks for your response.
Doug
Wisconsin
