Stay Straps
used car salesm
12-07-2004 14:28:50
What do staystraps do? I have a brand new pair that came with the tractor and dont really know what the use is for them. they can be found on page 208 of the 2004 TSC blue book.
I have the same backblade..... what do these things do?
thanks !!!
Steve(OR)
12-07-2004 15:22:47
 Re: Stay Straps in reply to used car salesman, 12-07-2004 14:28:50
They connect to form a triangle from the ends of the lift arms to the top link rocker. The bottom the triangle is the 11 hole drawbar. The function is to keep the drawbar at a fixed height when used to tow implements and trailers. You really need to used both stay straps and stabilizer bars at the same time when towing stuff. And don't use the lift hydraulics with stay straps cause you'll break something.
SteveB(wi)
12-07-2004 15:47:38
 Re: Stay Straps in reply to Steve(OR), 12-07-2004 15:22:47
third party image
You don"t need stabilizer bars with the stay bars. The triangle will keep it from swaying. In fact my factory 11 hole drawbar doesn"t have long enough pins to allow you to use them. The original stay bars had a chain, warning tag, and bracket that slips over the control lever so you cannot use the hydraulics and bend things.
