Jump starting a 6 volt positive ground
Paul T(MI)
08-31-2004 14:34:50
Can I jump start a 6 volt Positive ground with a 12 volt Neg ground system? and if so,do I connect pos to pos or what? Any help is appreciated!
Steve(OR)
08-31-2004 14:59:52
 Re: Jump starting a 6 volt positive ground in reply to Paul T(MI), 08-31-2004 14:34:50
MAKE SURE TRACTOR IS OUT OF GEAR (you are bypassing the starter switch safety interlock and could get run over otherwise). Connect jumper cables to the good 12V battery. Connect either cable to the big post on the starter (Starters turn the same way regardless of how they are hooked up). Turn the ingition key to on. Touch the remaining cable to a good ground away from the battery. Tractor should start, then disconnect all cables.
