FRAM C3 or CP3?
Marc NY
02-19-2004 06:30:38
I read a post a week ago listing all the filters the 8N liked! Said C3 or C3P . I bought a C3, for 1/2 the pice of the C3P , but it is 1/2 the size (shorter),
Was that post a mistake, or is it ok to use the shorter C3? It didn`t come w/gasket, but I change frequently & know I have a good gasket . THANKS
souNdguy
02-19-2004 06:37:21
 Re: FRAM C3 or CP3? in reply to Marc NY, 02-19-2004 06:30:38
If the box with your c3 in it had a filter that was shorter than the c3p.. someone swapped filters.
The c3 and c3p are virtually identical in size.. though as you noticed.. the c3 is about 4$ & has no gasket, whereas the c3p is about 8$ and has a gasket. Also.. the c3-p has lots more filter media in it... And looks better constructed. I.e., it has a filter paper over cover.. etc..
If I were doing an oil change on a machine that was going to need another oil change quick..like one that had been setting, and had lots of MMO in the oil helpin ghte valves and rings seat.. or if I was doing the first oil change after a blown head gasket.. etc. I would use the cheaper one.. as it was only going to be a 'few hour filter'
For the filter that I ran for 50 or 100 hours.. I would go with more media.
Soundguy
Thanks SounDer
02-19-2004 07:06:47
 Re: Re: FRAM C3 or CP3? in reply to souNdguy, 02-19-2004 06:37:21
C3P it IS. While I got ya, I filled the steer box w/80-90 & noticed the oil leaking all over the side (left) . looks like the sector arms are leaking. Fo4 manual shows a couple seals. are they still avail, & can I just change em? Looks like I can
THANKS Marc
John TR
02-19-2004 11:54:54
 Re: Re: Re: FRAM C3 or CP3? in reply to Thanks SounDer, 02-19-2004 07:06:47
Doesn't the steering sectors on the 9/2n get splash oiled from the tranny? I think there are drain holes back into the tranny
souNdguy
02-19-2004 22:00:34
 Re: Re: Re: Re: FRAM C3 or CP3? in reply to John TR, 02-19-2004 11:54:54
AFAIK they do.. but both the 8n boxes are sealed and must be lubed..
Soundguy
