Order Ford 9N Parts Online
9N firing order and wire locations in dist ributor
JR
11-07-2003 05:26:02
Can someone help me with the firing order for my 9N Ford, and also the wire positions on the distributor cap (if read as a clock, to the 1 o'clock position, to the 4 o'clock position, to the 7 o'clock position and the 10 o'clock position).
Sure would appreciate the information and Thank You.
Bruce (VA)
11-07-2003 06:05:42
 Re: 9N firing order and wire locations in dist rib in reply to JR, 11-07-2003 05:26:02
JR, what Dell says.....and, the new caps (at least mine does) have the cylinders marked under the nipples.
Dell (WA)
11-07-2003 05:56:58
JR..... ....firing order of 4-nipple frontmount distributor is 1,2,4,3 CCW.
This means: sparkie #1 is connected to nipple #1 at 10 o'clock
sparkie #2 is connected to nipple #2 at 7 o'clock
pretty straight foward right? NOW PAY ATTENTION it getts tricky here
sparkie #4 is connected to nipple #3 at 4 o'clock
sparkie #3 is connected to nipple #4 at 1 o'clock
therefore firing order is 1,2,4,3 CCW, isn't that amazing?..... ..respectfully, Dell
