Order Ford 9N Parts Online
'39 9n distributor
Dave Ruckle
04-06-2003 16:09:31
My 9 has developed a pretty severe block crack-upon tearing it down for a HOPEFULLY successful repair in the near future... I found the distributor face is cracked where it contacts the crank. The surface is cracked about 1/2 way around the rise where the distributor shaft comes out. Do I need to replace the distributor? Or is this not really a problem- I don't know if any fluids could enter or would present a problem.
Thanks for the help..
Dell (WA)
04-06-2003 17:16:56
 Re: '39 9n distributor in reply to Dave Ruckle, 04-06-2003 16:09:31
Dave..... ...while I don't think that there is any cause/relationship between your "cracked block" and your "cracked distributor". YOU NEED TO APPEASE THE DISTRIBUTOR GODS by rebuilding your distributor. Parts are available and NOT THAT expensive. Consult your I&T FO-4 manual $29 (cheap)..... ...Dell
