I'm working on a Ford 8n 6-volt. It was running when I parked it, I didn't use it this winter, and now its time to shred weeds.
I've charged up the battery. When I turn on the key, the amp gauge moves a bit, but when I press the start button, nothing happens.
I started with the battery, making sure it had charge. Then moved to the cables, which look solid, but I shined up the posts and cable leads to ensure a good 6-volt connection just in case.
I jumped ahead of wiring issues because its been running great.
So I jumped the starter with another battery and the engine turns over, but does not start.
I placed an inline spark detector on a spark plug, cleaned up the points, and tried again. There is no spark through the spark tester.
I pulled the key switch and tested it, and it shows 17ohms when the key is turned on, and nothing when the key is off. Which I assume is normal.
Next to test, I assume is the start button. I'm not sure how to test this.
NOTE: when i press the starter button, there is no solenoid click.
I'm familiar with some automotive 12 volt issues, but this is the first 6 volt I've encountered. So many people I've talked to have told me right away to convert it to a 12 volt system with a GM 1-wire alternator. As of right now, I'd like to keep it original 6-volt, because it seems like a fairly rare tractor, being propane powered.
Any help is appreciated.
This post was edited by -=CRANK=- on 06/23/2021 at 08:09 pm.
