Wrong engine "not a smooth block" and has 136 in casting near starter,can't lift the serial #
THE GOOD,
Early radiator w tear drop fan "rear thrust",chrome cap,throttle tip,pto position lever,and 3 point adjustment tip are chrome. Hood is pop in style,smooth dog ears. Aluminum dash/column "key on right", timing cover,govenor plate,govenor " non oiled type"pto covers,quadrant,bottom trans plate. Magalloy to the max.
Has 32" hat trims and a dash button auxiliary step up. Not sure if it's a Sherman or a Howard.
My understanding is the chrome tipped pieces were early 39s ??
Non oiled governors "no oil line" were used in very few units??
THE GOOD,
