icephan2000
New User
Disclaimer: Mechanically illiterate.
'49 8N, 12V converted.
This is my current wiring arrangement when purchased. I want to delete the wonky 3 wire ignition switch and replace it with the proper 2 wire, 2 position switch. HOW do I install? And I'm not seeing/finding the "factory resistor block" I've been told to use..?? I've been told the resistor is from the conversion. LOST and all alone in the Pea Patch!
