Over the past few month I was having trouble with the engine cutting out with and without load. It would start out with the cut out then then improve but not the last time out, it just got worse. I cleaned the plugs, installed new points, condenser & rotor. Started up ran fine for a few seconds then died. The distributor had spun clockwise and was stopped by the oiler(dist hold down clamp/bolt as not tight.) Pulled dist cap and rotor was in several pieces. Not sure if I damaged the points. I had also not clamped the dist cap and or dust cap securely. I replaced the rotor, points and dist cap but I can't get the dist and rotor to align with the number 1 dist terminal. I did pull the number 1 plug and got it to the compressing stroke but the rotor was pointing down so I loosened the dist to make the alignment and the dist would not move to that position. So I tried to start it up and the exhaust would puff grey smoke and with small pops while cranking. I changed the ignition switch but that wasn't it. Getting fuel from bottom of carb screw. Any ideas/thoughts would be appreciated. Pretty sure I have the timing screwed up but don't know how to straighten that out or may be other problems. Thanks, Ron
