I have looked at a wiring diagram by JMOR, for the 9n. The wiring diagram shows the wire connecting to the top of the cutout, to be from the battery. I have a cutout that I removed from a 2n. It has Ford stamped on it, and the B is on the lower front of the cover, not the top. It seems that it would be mounted so that Ford is not upside down. I assume that this "B" terminal would be for the wire that connects from the battery to the amp gauge and resistor block and then to the cutout. Do I wire it as shown in the diagram or do I put the battery wire to the B terminal? Or can it be wired either way?
TY
SDE
TY
SDE
