avant 1735
Looking on putting electronic ignition on an 8 N with a front mount distributor (positive ground 6 volt). I have found the parts, but I have questions:
Can you use the same spark plug wires after the electronic ignition is installed? or do they need to be changed to carbon core wires? There is one wire on top of the coil coming from the key, is this where the wire from the ignition system connects? Is there a possibility I will need to re-time the motor after installation?
I have installed a few petronix ignition systems on other tractors with the more traditional type of distributors on them, but not a front mount ford. Any information would be very helpful and appreciated. Thanks
