8nfamilytradition
New User
Hello all,
New to owning 8ns but passionate about learning about them.
I get my 1950 8n good running tractor to start most times on first attempt, while it is the first start of the day. I then work the tractor and shut it off to rest myself or I just start it, let it warm up, and shut it off util I need to get on it.
I try to start it a few minutes later, AND NOTHING, It cranks good while holding the starter press foot switch, but it just starts to run while holding the starter foot switch, then dies when i let it up. I do this several times, we hv gas, but seems like no spark. I've checked the coil, electronic ignition cap and spark plug wires. They all appear good.
I noticed that the top cover plate of the 6 volt EI has a bolt that is supposed to hold it down securely to the distributor housing. It is to short to reach the threads to engage. It doesn't seem that it would be messing with the operation of EI, As they have the side clips to hold it.
It's just very wierd to me that it runs so well after starting while doing work or warming up, and this issue is so sporadic with the way it happens. I started it earlier today, and it wouldnt start first try. Then I traced the ignition wires and all were connected an tight, except that distributor plate I mentioned earlier, so basicically i mov3d the wires and parts.
Let it sit a few minutes and it started right up, but with BLACKblue SMOKE and then very clear exhaust,I let it run about 5 min, then it started 5 times after shutting it off after warming, in consecutive on/off rotations. Clear exhaust. Then wouldn't start,but good crank
What do you think
What do you think
