(quoted from post at 16:11:04 12/11/17)
(quoted from post at 06:41:26 12/09/17)
My points cleaner is a piece of fine sandpaper :shock: I am not going to chase my tail all day over a dirty set of points. They are sacrificial and can be replaced once they are eliminated as the issue if not they can still be replaced... Its a no brainier to me I am not out to salvage every set of points I come into contact with.
Open line voltage does not mean much to me and that's the number one reason no start no crank issues go on for page after page until they get lucky and find the source of the voltage loss/drop. The correct way to test voltage is to put load on front of voltage. It should read like this...
Check loaded voltage across the open points. That's important.
Ones loaded voltage is eliminated you can move on till its not eliminated its a prime suspects.
Any voltage check of the ignition system should read loaded voltage not voltage, open line voltage is a ghost and will eat your lunch. It will eat the best lunch you can bank on that.
I checked the voltage with the points open or as close as I can get to top of the lobe and I'm getting 6.22, basically what the battery has in it currently without charging it.
I cleaned the rotor (had a decent amount of carbon on it) and the points. I have not checked the gap on the points or spark plugs yet though.
I took the plug wire off the top of the Dist cap from the coil and I have good spark that will jump .25 inch.
Plus, I drained the gas tank, cleaned the screen in the elbow. I'm replacing the screen/gasket in the bowl and I need to pull the shut off valve yet to check the screen in the tank while its empty.
Ran out of time for everything else.
