Re: Intermittent Spark 8N, Now Carb problem
Jim L WA
It could be the carburetor, but could also be a vacuum leak. But I would try adjusting the main jet first.
" I get a good flow until the bowl drains, from then to its not a steady stream, more of a fast drip. Does that sound right? "
No, that's not right at all.
See tip # 21.
You have a fuel obstruction.
It might be the line, but it's probably a port in the sediment bowl.
75 Tips
