AlabamaJim
My 12v conversion kit has decent wiring instructions, but the instructions for the brackets really suck. It appears the entire assembly is held in place by one single bolt. '52 model, so we're on the left side. The lousy picture shows the primary bracket bolted to the top loop just behind the radiator hose that used to hold the old generator bracket. From what I can see, that is the only thing holding everything in place. I know there's lots of 12v N's on here, so I'm probably not the only one, unless I just got a crappy kit. Also, the original bolt won't even go through the slot in the bracket. Looks like a 5/16 bolt would be max for it.
Thanks, Jim
Thanks, Jim
