bensonshaw
New User
Hello, I'm new to tractors and recently bought a 9N. I have a question about the throttle lever.
When sitting on the tractor, the throttle lever is right hand side of the steering wheel.
Along with the lever, there is a type of plate that it rests on, and the plate has notches in it.
The extremes of the lever is either up or down.
Down is more toward the driver set, while the up is more towards the front of the tractor. This isn't exactly correct because the lever does not sit parallel.
In the down position, is this the idle or lowest RPM setting of the engine? And up position wide open throttle?
Any help would be appreciated. Thanks.
