Hupp Transmission Shifter
Hi All. I have an 8N with a hupp transmission. From what I see online of the shift pattern, the shift handle pulls out from the transmission case. Now I can move it up, down and horizontal but not sideways--not enough clearance between the pitman arm and the trans. case. What am I missing? Thanks in advance.
The Hupp has 3 ranges. Put the lever in the middle position (neutral), move the handle outward and then up to be in the underdrive position. There is a manual on that other website.
Hi John. There's no room to move the lever out-it has a quarter inch before it hits the pitman arm (for steering).
Sounds like either the lever is bent or modified or the steering arm is bent. My e-mail is open. Send me your e-mail address and I will send some pictures that I just took and a short video.
whereswaldo ,Does your shifter have a round knob or does it have a flat end on the shifter.The round knob shifter is the Hupp Dual-Drive transmission,the flat handle is Hupp overdrive transmission.
Please excuse me, I don't mean to take over this thread:
I have an aux. trans, that I believe is a Hupp. Where can I find out more about it so I can tell folks I have it and don't need it.
Dennis M. in W. Tenn.
I don?t know much about the HUPP but these may help. You can get these and the entire manual/service instructions over at the other N-SERIES TRACTOR web site for FREE download.
HUPP DUAL DRIVE TRANSMISSION FOR FORD TRACTORS:
Tim *PloughNman* Daley(MI)
Thank you. Mine IS flat and I've NEVER seen this in any literature! I've had this nearly ten years and had seen the shift pattern but never knew there was a difference.
