1952 Ford 8n block troubles
mikewood869
Bought a 1952 8n two months ago (has proof meter) and over the weekend we were cleaning and tearing the block down and found a long crack that is probably 12 inches long. Would this be a problem? It end right we’re my finger is.
(quoted from post at 05:45:36 08/06/18) Replace
That sucks. Anyone needs parts :( (joking). Could this be a reason that the motor wouldn’t have enough compression because I don’t think it had any.
As for the crack I don't think it will affect compression as for issues the crack may cause like over heating YES.... Its hard to dump good money into a cracked block that crack will always be a issue of some kind...
I volt replace if a gambler roll the dice...
A up draft carb does not work well as a down draft carb I spec it is hard to get it to run'N...
If you were closer I could set you up with a side mount engine to build..
