1948 8N, Front mount.
Started great all winter with trouble light sitting against the carb to keep it warm. However been sick, have not started it
since at least the end of March (got cancer, doing chemo)...it is now August 3rd. Now it will not start, just cranks over. I
am going to swap plugs in the event I flooded it. I assume it still is not going to start. So, I need some suggestions. I
have some starting fluid, but I am not sure how to use it...will it work if I spray it into the air intake (that is, will the
fluid make it past the oil bath in the air filter?). Any other advice (other than pull/push it...that is not possible inasmuch
as it is sitting in the barn with a mower attached). Gas gone bad?
