9n or 2n Rear Axle Hub
Garryllk
Hi the machine shop called and said they might wreck the hub trying you press it off< Does any one know where I can buy just a rear hub for this tractor ?
Thank You
Garry
That would be great
I don't want to buy the whole axle with hub and that is the only way I could buy one. It would be the same prob as this is because I would still need to get the hub pressed off and replace the bearing and seal.
I added my email address here.
Garry
(quoted from post at 10:49:46 08/02/18)
Hi the machine shop called and said they might wreck the hub trying you press it off&lt; Does any one know where I can buy just a rear hub for this tractor ?
Thank You
Garry
Find a machine shop that knows how to do stuff....
I pressed the hub off all the axles I had at the time I posted this were I put'em well who knows if needed I will look I do know I have never sold one :wink: I figured I never would sale a hub cuzz most cheap arzses will never go there and fix it right the first time...
http://forums.yesterdaystractors.com/viewtopic.php?t=571655&amp;highlight=puller
Now to call out someone to warn you it may go bad maybe they need to go in the machine shop businesses and guarantee every thing they touch.. :roll:
I always guaranteed my machine work weather it was done in my
shop or working in someone else s shop .
If you cant back yer wok it aint worth manure !!
Thank all of you and your right
I went there yesterday and I talked to the owner and showed him how to do it from what I saw on that 10 hour vid on you tube of him doing the whole drive train.
This is a very big machine shop though But never did a tractor axle and he was very nice Even about needing to build some supports to hold the hub on the press.
c&c Machine out of LaCrosse Wis.
I asked how much this is going to cost and he said he will keep the price he charges me down . So I have the other side to do which is leaking worst than this side so more work for him.I don't know if I will need a hub But I differently am not looking forward to getting that other collar off the other side
Thanks to everyone that replied
Garry
