Does anyone know how the Fuel Tank Liner Part No: R2043 is distributed in the gas tank?? What I want to know is if the tank has to be removed so that it can be sloshed all around in the tank to get a good coating all over the entire inside of the tank. Also will it hold loose particles so that they stop circulating around the tank and end up in the fuel strainer?? My 8N tank has a lot of rust and the strainer wasn't on it so it only runs a few minutes at a time and I have to drain the tank and strain the fuel. So far I think I've done it 3 times and removed between a cup and a pint of solid rust particles, I just ordered a new sediment bowl and strainer assembly, but I don't know how much more loose rust is left in there. Was thinking a liner might solve the problem by binding the loose rust. Thanks
