Water Temp port
I have a question about a water temp gauge port. The head that came on my tractor had a port on it but it had cracked somewhere over the years and had been brazed up so I used one of the other heads I had and none of them has a port for a temp gauge. Is there a sleeve that goes in the radiator hose or somewhere else to add the temp gauge. Jim note the stool in the background.
ps: if the other heads are 8N heads, with the flat spot up front, u could drill and tap it. mine's a 2N head, no flat spot.
there is such a device made for that but I can tell you that it will look a lot better if you have a new hole tapped in your head for the sender. It will look more original although I have been told they never came out from the factory with temp gauges.
yep, no such thing as an original temperature gauge setup.
as far as looking a lot better, shrug - iirc, u can't even see the adapter unless u lean over and look for it.
(quoted from post at 15:11:46 07/23/18) Why do you say everything twice?, why do you say everything twice?
b:d5c8120255][i:d5c8120255]
That's Funny!! :lol:
But......I'm thinkin' that is caused by a worn/dirty ' Enter key' on his keyboard.
Dust getting under the 'most used' key switch ,wears out the seat and spring under the key top, letting the switch 'bounce' when pushed!!
BTDT!!!!!
Keep the key board clean.....makes for a good/long lasting keyboard!!
JMHO!!!
Gary[/i:d5c8120255][/b:d5c8120255]
[quot can u tell mee="HFJ"](reply to post at 16:53:54 What type of heat gauge did u use i want to put 1 on my 8n07/22/18) [/quote]
I have several old gauges on the shelf, I got a matched set for this tractor but I put an old S/W gauge on my brothers 9N
(quoted from post at 10:02:46 07/25/18) I have several old gauges on the shelf, I got a matched set for this tractor but I put an old S/W gauge on my brothers 9N
ow did u plumb it into the upper radiator hose?
