Tie rod ends
gblj
We put a new Tie rod end on my 8n, when I try to grease it i can't get it to take grease, any help here.
remove the fitting see if it takes grease. sometimes you get one that has a bad zerk.
if the zerk passes grease, reinstall it and jack up the front a bit and take pressure off that joint and rotate it and see if it takes grease.
I jacked up the front end to take pressure off, still won't take grease, I also replaced with another zerk, still won't take grease.
