Replacing ring gear
Troyhudd
New User
I?m having to replace the ring gear on my 8n. I?m planing on putting a
new throw out bearing pilot bearing and a transmission input seal
while I have it apart. Is there anything else I should replace or do
while it?s apart? Thanks for the help.
Troy, welcome to the forum - Glad to have you!!
Assuming you are replacing the starter ring, sounds like you have a good plan.
Good luck with your project!!
Splitting the tractor & replacing the clutch is covered nicely in the I&T FO4 manual. (see tip # 39)
See tips 12 & 59 before you split it.
Following the premise of 'if you are in for a dime, you're in for a dollar'...?...
Have the flywheel resurfaced.
Replace the Bendix.
In addition to replacing the t/o & pilot bearings & front transmission seal while I was in there, I'd have the clutch & p/p rebuilt.
Use the main shaft as your clutch alignment tool.
If you don't have a local rebuild shop, try these guys:
Automotive Manufacturers Inc
2400 N Lombardy St Richmond, VA 23220
(804) 321-6861
They do mail order work. They rebuild carbs, clutches, pressure plates, water pumps, alternators, generators, starters & reline brakes.
If you prefer new parts, do NOT order them off of eBay or buy them at TSC. Get parts (and the manuals) from this site or nnalert's.
75 Tips
