Hi
I have another question about my 2n.
Wanted to put sure seals on both axles and new brakes, But when I got the wheel off I went to take off the 8 bolts with 3/4 nuts that hold the hub on.All eight bolt's just spins,so I wonder what to do? All eight do this.I don't have a cutting touch So only choice would be use a side winder to cut all of them off.
I thought they would be like studs on a car and the bold has splines so it doesn't turn when you try to take off the nuts ?
It's possible who ever owned this tractor messed these up to. The rim had 2 different size nuts holding it on
Thank You
Garry
