Hey guys. Aside from the issue of my N lifting a reduced load (it is to the point where I'm having trouble lifting and keeping the brush hog at a set point), when it is in draft control it won't lift the arms unless I push the selector lever down past the spring loaded stop. Can someone coach me through the troubleshooting and repair steps for both problems? I'm going to pull the inspection plate tomorrow night
Pushing the draft/posn lever past the spring loaded stop helps compensate for the worn cam follower pin. Holding position is related to same wear, but you probably have leak at ram cylinder, too, so look i the inspection port for that when trying to lift a load.
