TractorLinks.com
Show Parts for Model:
Rod and Main Bearings
NCMau
07-11-2018 15:42:22
Restoration of a 52 8N. Finally got the rod bearings after a vendor screwup. Main bearings have been in place, but I have a question. Before installing these bearings, I saw couple of UTube videos, where they did not mention about removing the plastigage after the test. I did not realize that it had to be done until I saw a later video where the mechanic removed the plastigage.
I wonder how important is to remove it. I had assumed that the plastigage would just liquify. Since I am still working on the bottom, should I try to remove the main bearings and clean the journals, or that would not be necessary?
R Geiger
07-14-2018 20:04:24
 Re: Rod and Main Bearings in reply to NCMau, 07-11-2018 15:42:22
Since you have to remove a bearing cap to see what you, I sure don't know why one would not clean it off, and besides like Royse says clean them off and lube them with assy lube of some sort.If the main do not ahve assy fluid or oil on them I sure would remove the caps and clean and lube them.
Royse
07-14-2018 19:41:49
I always remove it, but that's because once I've measured the gap
I clean all the bearings and coat them with assembly lube so they
are pre-lubed during hand cranking, oil pressure building and then
on initial startup. I'm not a professional mechanic by any means,
that's just what I was taught. So far it has worked out well for me.
NCmau
07-12-2018 04:19:46
Good clarification. I guess i will leave the mains in place, but I will clean the rod bearings when I get to that point.
hunkydory
07-11-2018 16:19:24
Plastigage is used to measure the clearance. Ideally it should be removed. However, it will dissolve on its own. Refer to the last paragraph in this link:
http://www.plastigaugeusa.com/how.html
