oldford647986
Ok I have a 9n 12v front mount distributor and an 8n 12v side mount distributor. Both have the same symptoms they were running fine then would only start and run for around 30 secs then die. Carburetors have been gone thru as well as screens and fuel lines. I have good flow. Spark has been checked and is good on both tractors spark good strong blue arc across 1/4" gap. Compression has been checked 9n 1-4 145,145,160,155 8n was 100 on all 4. And if trying to crank if chiked the intake will show fuel.Both will try to start and will sputter slightly but will not run. I am at a loss i have went over everything and cant figure it out.
