TractorLinks.com
Show Parts for Model:
distributor clip
fubar2
07-09-2018 23:16:10
I've been rolling this around in my empty hear for a couple days and can't imagine what the clip that goes under the rotor and on the dist. shaft actually does. If it is to set the rotor height, wouldn't the dust cap serve that purpose? In order of assembly isn't it clip then dust cap then rotor? I just can't picture any actual function for it other than just go round and round. An early thank u to anyone who can enlighten me.
fubar2
07-12-2018 08:48:36
 Re: distributor clip in reply to fubar2, 07-09-2018 23:16:10
No problem.
JMOR
07-12-2018 07:47:29
Quoting Removed, click Modern View to seeSorry about that fubar2, your post just got sandwiched in between beige35 & me. My response was intended for beige35.
fubar2
07-12-2018 07:35:30
Quoting Removed, click Modern View to seeThere seems to be some confusion here unless you can point out where exactly I said they screwed up. You may want to reread the posts. What I mentioned was the fact that Henry specd. the pallets of ordered parts to fit his cars and he would cut them to use as free floorboards. Didn't even mention it just alluded to it. I got no chain of evidence on his, Delcos or anybody's dist. shafts.
JMOR
07-12-2018 01:59:15
Quoting Removed, click Modern View to seeI will get to my opinion sooner or later, but first I would like to know your chain of evidence leading to the conclusion that a Ford screw up made the shaft too small.
fubar2
07-12-2018 00:28:33
Please do elaborate JMOR. I haven't yet gotten an answer that holds much water and I am curious. It's been years since I've been inside a points dist. but I don't remember seeing a clip inside until my first look inside a Ford tractor.
JMOR
07-10-2018 20:31:18
Quoting Removed, click Modern View to seeBS
fubar2
07-10-2018 20:05:11
Well, at least Henry used a metal clip and not something he whittled out of a made to order specd. pallet.
R Geiger
07-10-2018 08:31:48
Dust cover, clip, then rotor. install rotor without the clip and feel it for looseness, then install rotor with the clip and feel the difference. The rotor needs to be snug on the shaft.
soundguy
07-10-2018 08:09:01
spacer
try the rotor with no clip..
WayneIA
07-10-2018 09:59:53
 Re: distributor clip in reply to soundguy, 07-10-2018 08:09:01
And half the operators will not know the difference
soundguy
07-10-2018 10:57:39
 Re: distributor clip in reply to WayneIA, 07-10-2018 09:59:53
They should know it when it runs like doodoo!
Tim PloughNman Daley
07-10-2018 01:11:51
Are you talking about the spring clip, p/n 8N-12213, that goes on the shaft of the angle (side) mount distributor beginning with the early 1950 8N?
Tim Daley(MI)
beige35
07-10-2018 18:08:32
 Re: distributor clip in reply to Tim PloughNman Daley, 07-10-2018 01:11:51
This was a Ford screw ip a way to fix the rotor as the shaft was made to small
