[email protected]
New User
I just purchased a new hyd valve body, piston, and 3 rings for my 8N ford. Installed the rings very carefully by hand to make sure there was no problem going together. But now that I have it installed and running the lift will barley raise the blade even at high idle and I removed the inspection cover and raised the blade and watched the hyd body after I turned the engine off and oil just streams out of the body as the blade comes to the ground. I staggered the 3 rings as you would do on any piston so I am at a lose of what is going on. Any suggestions will be appreciated.
Thanks
Dale
Thanks
Dale
