8n Radiator Bubbling
Hey guys first message in a long time I apologize for coming
back in on something basic. My 49 Front mount radiator is
making boiling noises and excess coolant is coming out of the
overfill line. I?m sure I added too much coolant and some of it
is excess overflowing, but it just seems like I?ve never heard it
gurgling and bubbling before ? Are these noises normal ?
And just to be clear I don?t think we are overheating nothing is
coming out of the radiator cap 100% of the coolant is coming
out of the overfill line .
Could be un-purged air in the system, blown head gasket, sticky thermostat or as you indicated just simply overfilled.
Back story on the tractor will help with further diagnosis.
(quoted from post at 00:53:08 06/18/18) Hey guys first message in a long time I apologize for coming
hen the cap opens due to over pressure, that line is the relief path.
Is it overheating? Do you have a thermostat installed correctly -pointed end towards radiator? If you answered 'NO' and "YES", then get the level amount set right, check the fan belt tension and water pump slop and move on. If your radiator is old and in need of a flush/cleaning, then do it. It's all part of standard preventative maintenance. The old adage applies too -"...if it ain't broke...don't 'fix' it..."
Tim Daley(MI)
A few possibilities.
1, run it with the cap off.. does it constantly bubble... if yes.. might do a leakdown test, ( head gasket issue possibly ).
2, Are you running a bit lean and getting her pretty hot?
(quoted from post at 21:53:08 06/17/18) Hey guys first message in a long time I apologize for coming
There is something else no one mentioned. When was the last time you cleaned out your radiator fins? Those radiators can pick up a lot of crap to reduce cooling, especially if you do any mowing. Thank about it, these tractors are mostly run on dirt.
You'd be surprised how much crap can accumulate in those fins. You need to use something like in my picture. It's just a regular air nozzle with a brass barbed fitting to accept a plastic hose. I use it to get into and blow out the radiator from both front and back. I also use a garden hose with a high pressure nozzle on it. Those radiators work a lot better when they're kept clean.
Thank you for the comments . I did some research before I
posted last night and already intended to do a flush it?s been
many years since I flushed it . I reinstalled a water pump
about eight years ago at which time I did a full flush on the
radiator . I never messed with the coolant until this year when
I noticed it was low and I added now what I believe is too
much . However it?s still making bubbling noises when I gets
hot . And now for a little more on the backstory the tractor has
been squeaking for a while. Sounds like the squeak is coming
from the alternator and not necessarily the belt but who knows
. I have also read on older posts regarding this subject that a
squeaky noise could indicate a bad water pump . When I go
back up to the farm this weekend I will run it with the cap off
and watch to see if there is circulation .
Soundguy... it bubbles after I shut her down.... like it?s boiling inside ? Could there be a combustion gases from a blown head that are trapped in the system that are still coming up
Heatsoak and boil at shutdown might mean she is lean and hot.
Open the rad cap when cool, and run and look for bubbles.
(reply to post at 23:06:40 06/18/18)
anvilhead, i had these same boiling noises when i got my N, and still do. for years i was convinced it ran hotter than anything else i'd ever used. and ya, when it was filled by someone (no names mentioned) who didn't know the trick, it blew coolant back out.
fast forward to this year. i finally got around to installing a temperature gauge this past winter. imagine my surprise to discover that my N never runs above 160 degrees. only when i turn it off does that gauge go anywhere near boiling point. so, it's either non-circulating water being heated up by the still hot engine, or it's the gas boiling in the tank :shock: :)
