Ten Feather
New User
I have a 1947 Fordson 2N, 4 cylinder, front mount distributor. It just flat quit running the other day. The Coil burned up. I replaced the coil, cap, rotor, points and condensor. It is a 12 volt conversion and has ran great for 3 years. So, I installed an in-line Resistor. It started up and ran for about an hour, then quit! I took the distributor back out and found that the copper ribbon going from the mounting where the coil spring touches that screw to the points screw was shorting out on the condensor wire end and is burned almost into. Does anyone out there have a Distributor Breaker Plate with a good copper ribbon? if so, please call Charlie,
(858)945-6838 or E-Mail me at:: [email protected]. :?: :?:
