8n steering arms
One way is to use a "pickle fork". A decent auto supply should have them. But it can be hard on the rubber seals.
A good way is with a wood splitting wedge between transmission housing and steering arm behind drag link end,after the nut has been loosened a few turns.Then wedge it in and hit the steering arm with a BFH to knock it loose.No damage to anything and easy to get it off = smiles.
(quoted from post at 12:49:56 06/11/18) One way is to use a "pickle fork". A decent auto supply should have them. But it can be hard on the rubber seals.
If you're going to the trouble of disconnecting them wouldn't you put in new seals anyway? I know I would.
