I have a 51 8N with a side mount distributor. I had the tractor running last year but it has always been hit or miss with starting. Would only run when I turned the distributor full advanced. This year it wouldn't start at all. So I put on a new cap and rotor but it was running very poorly and still extremely hard to start. I then put a new coil and new points. I have never really done points so I did my best to adjust them to 0.25 with the supplied feeler gauge. After that, the tractor wouldn't start at all. Then I did what in hindsight is a mistake - I reset the distributor and timing according to the manual. Tractor still doesn't start. Verified that there is a bright blue spark from the coil. Verified the spark plugs are sparking when laying on the head. Took off the gas tank for easier access so I am starting the tractor with a funnel and a rubber line now. However, what is most curious is that when a take the lead off #1 cylinder, the tractor starts almost instantly! A little stumbly, but not too bad. Then when I reattach the lead to #1, the tractor dies. Next, I took off the spark plug lead to cylinder #2 and the same thing occurs. Starts right up, stumbles, but when cylinder #2 lead is reconnected the tractor dies. I figure there is something wrong with the timing of the spark. My firing order on the cap is 1-2-4-3. Does anybody have any ideas on what to try next or how to appropriately troubleshoot the problem?
