8N with woods belly mower
OLDFORDS
New User
Hello all, does anyone now the correct belt size/part number for a Woods 59 inch belly mower under a 52 8N ? The last won a got never seemed right and got tore up pretty quick. Thanks
I would try the simple first. Look for a model number on the mower and take it to your local Woods dealer.
If you can't find a number pull the belt guards off and take some photos of it so the dealer can maybe ID it that way.
Thanks, but thats part of the problem, there isn't a Woods dealer nearby, last year I got this belt through a John Deere dealer and it didn't hold up. I'm gonna try reaching out to Woods, maybe they can help.
(quoted from post at 11:24:17 06/07/18) Hello all, does anyone now the correct belt size/part number for a Woods 59 inch belly mower under a 52 8N ? The last won a got never seemed right and got tore up pretty quick. Thanks
Just ask Google:
[color=red:8dd1280372][i:8dd1280372]"If it were that easy! Depends on the version of Woods 59. The 59CL-1 and 59CL-2 take a 4152. The 59CL-3 and 59CL-4 take a 3492"[/i:8dd1280372][/color:8dd1280372]
TOH
OK thanks, except it's an old mower deck with no ID on it, can I assume that a 59CL-3 is a 3 blade, 3 spindle ? I hope so cause that's what I have. Thanks again TOH
OLDFORDS
VBelt Global supply says the V4152 is 213.4 inches and V3492 = B204
You should be able to measure your old one to see which is closest.
I have good luck with VBelt Global supply.
