9N/2N 16 Rims
Den N Ms
Saw this good deal on a pair of very very hard to find 9N/2N 16" front wheels,and they look to be great shape!Where were these at when I was needing a pair and went through all work/time building a pair?
Rims
Did you know that the 1938 ford car had the same bolt pattern as the 9N?
I had a 1938 Ford business coupe. Wish I had it back!
Zane
I used to have a 37 Ford Sedan which I sold back around 1984, I believe I still have a couple of extra rims in my Dads old shed, if the 38 fits I bet my 37 is the same wheel
"Did you know that the 1938 ford car had the same bolt pattern as the 9N?"
Actually they're not the same Zane. The whole hubs will interchange,
but if you want to bolt the rims to 9N/2N hubs you have to drill new holes.
I have a set that was drilled and mounted just like that.
That's a great deal on the rims and tires though.
I have a set of them I had sandblasted, repainted and new tires
and tubes put on them. I "might" take 3 times that for them.
They've never been on a tractor since the tires were mounted.
That brings up a question. Are 16 inch rims correct? My '44 came home with 4.00 x 19 (Riverside) tires on it.
