JerryC2011
I have an 8N with front distributor. I purchased it 3-4 years ago for $500. it needed a steering shaft with the worm gear, a rebuilt starter, and a tune up. I also converted it to 12 volt and bought a new battery for it. Total spent add another $500.
I got it running, then discovered it the 3 pt lift would leak off rapidly. Pump appears to work fine and holds the lift when running. I also discovered the left 3 pt lift arm pin is broke. The one under the rear axle. One of the PO's had drilled a hole and held it in place with a roll pin. Does not have adequate strength to plow with without pulling out.
Also one of the hat rims is rusted to the point it needs replacing. Rear tires are good, no cracking. And the rear axle leaks oil on one side.
One positive is that I know the PO put a new flywheel ring gear on it.
Q1: Have not tested compression yet. (I do have a tester.) Can a low compression motor fire and run on starter fluid, but not gasoline from the carb.? I did just rebuild the carb. Gas is flowing. I did change points, check timing, and changed spark plugs.
Q2: Since I am sick of messing with this 8n, and I just bought a 52 8N that runs, Should I take my losses and make it a parts tractor? I would like to get $500 out of it, but I couldn't sell it to anyone without notifying them of all the problems I know about.
I could stockpile in my parts inventory a rebuilt MS Carb., Two good used rear tires, one with a hat rim in good shape. A recently rebuilt starter, a good battery, 12v starter, lift arm parts, metal, etc.
Any wisdom / advice?
Thanks,
Jerry
Thanks,
Jerry
