I recently saved a clean looking `52 8N from the scrap yard.
when I first got it running, I had no oil pressure...I changed the oil again, and primed the pump by squirting about half a yellow
mustard squeeze bottle of 80-90 wt gear oil in the oil line through the oil pressure gauge hole in the dash, then replaced the gauge, started the tractor, and had about 15 to 20 # pressure.at half throttle
after it sat a few weeks, I went out to use it, and again had no oil pressure.
I think I need to Have TOH rebuild my Pump.
what`s the best way to R&R the pump...My FO-4 just says to remove the front axle assy, and lower the pan...but I think there`s a lot more to it than that. anyone have any good suggestions???
TomT
TomT
